Xone Forum Homepage
Forum Home Forum Home » Products » Xone:92
  New Posts New Posts RSS Feed - PHONO level
  FAQ FAQ  Forum Search   Events   Register Register  Login Login
Forum LockedPHONO level
 Post Reply Post Reply
Author
Message
PhenRoyer View Drop Down
Senior Member
Senior Member
Avatar
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote PhenRoyer Quote  Post ReplyReply Direct Link To This Post Topic: PHONO level
    Posted: 27 June 2013 at 7:13pm
Hello lads.
I have noticed that phono level in my 92 is a bit "different" than line in. When I use turntable (1210mk2) with ortofon cartridge (DJ blue) I need to move a trim knob to about quarter past position.
When I use cdj1000mk3 my trim knob is in quarter to, to twelve o'clock position.
This is not much of a problem or complain I was just wondering if you have same in your mixers ??
Back to Top
tomf View Drop Down
New Member
New Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomf Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2014 at 12:03pm
the same is true of mine, not sure if its meant to be like that or not.
It's all about the music
Back to Top
djkevinz View Drop Down
New Member
New Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote djkevinz Quote  Post ReplyReply Direct Link To This Post Posted: 05 October 2014 at 6:45am
The gain knob will probably be all over the place as you use different sources, especially different phono carts and different pressings. That's the point of the knob - so that the sound is the same level when your fader is at the top position (or wherever you normally run it)
Back to Top
  Share Topic
Forum Jump Forum Permissions View Drop Down
Forum Software by Web Wiz Forums® version 10.01
Copyright ©2001-2011 Web Wiz Ltd.
This page was generated in 0.094 seconds.
